need some advice or referral concerning my memtest86 results
  • sunnyjimm
    • Oct 2024
    Well i have been getting some crashes and instability so i ran the newest memtest86 on usb while i was away at work and obtained a big red FAIL in box and while i can run linux
    and have SOME technical ability so i can tell from the logs that this does not look good i thought i would ask if someone who knows this program and its log entries would give me an opinion
    on the logs that were dumped in the memtest86 thumbdrive so i can make a decision as to whether or not to replace the cpu, ram or both! OK now i managed to upload the logs but not the html
    summary i hope this is enough. Any help would be appreciated especially if an admin could look at this.
    There are a lot of errors in those log files. So definitely a hardware failure (or bad BIOS settings such as voltage levels and RAM timings)
    See this page to start with
    • sunnyjimm
      • Oct 2024
      thanks i guess i will have to do a bit more studying and research to find out what is going on. At least the test results are a start. Funny this seemed to start happening recently so i suspect
      hardware failure but maybe not we shall see. If there was a way to upload the html file maybe it would help.
        You should be able to copy paste the report into the forum. Example in this post.
        Uploading as a Zip or JPG is also possible.
        Allowing any random HTML upload is problematic from a security point of view.
        80% of the time the first step is to remove half the RAM and re-test. Then try the other half. Then replace all the RAM.
        • sunnyjimm
          • Oct 2024
          Well i cut to the chase, did an upgrade to 2 sticks of ram which upgraded from 16 to 32 gigs of ram, ran memtest86 and well after tweaking and using xmp (which IS supported by my ram)
          i obtained NO errors after a full run of memtest86. What an improvement ! So yeah i probably have a bum stick of ram. Finding out which one can wait for a rainy day (we have plenty of them
          where i live so no worries). My dual boot windows 10 as well as my win10 virtual machine also are working well too with no errors (they would not install some software updates and were unstable as well)
          This was my Old test result:
          Summary
          FAIL
          Report Date 2024-10-23 16:54:10
          Generated by MemTest86 V11.0 Free (64-bit)
          Visit MemTest86.com to Upgrade to Pro
          Result FAIL
          System Information
          EFI Specifications 2.70
          System
          Manufacturer ASUS
          Product Name System Product Name
          Version System Version
          Serial Number System Serial Number
          BIOS
          Version 2101
          Release Date 01/19/2024
          Baseboard
          Manufacturer ASUSTeK COMPUTER INC.
          Product Name ROG STRIX Z390-E GAMING
          Version Rev 1.xx
          Serial Number 181039217207328
          CPU Type Intel Core i7-9700K @ 3.60GHz
          CPU Clock 3645 MHz [Turbo: 4747.1 MHz]
          # Logical Processors 8
          L1 Cache 4 x 64K (197870 MB/s)
          L2 Cache 4 x 256K (85631 MB/s)
          L3 Cache 12288K (41374 MB/s)
          Memory 16307M (17141 MB/s)
          RAM Configuration DDR4 2400MT/s / x2 Channel / 17-17-17-39 / 1.200V
          Number of RAM SPDs detected 2
          SPD #0 8GB DDR4 XMP 1Rx8 PC4-23400
          Vendor Part Info Kingston / KHX2933C15D4/8GX / 0B5C2DA0
          JEDEC Profile 2400MT/s 17-17-17-39 1.2V
          XMP Profile 1 2936MT/s 15-17-17-39 1.35V
          XMP Profile 2 2666MT/s 15-17-17-36 1.35V
          SPD #1 8GB DDR4 XMP 1Rx8 PC4-23400
          Vendor Part Info Kingston / KHX2933C15D4/8GX / 0B5C2AE4
          Number of RAM slots 4
          Number of RAM modules 2
          DIMM A1 Empty slot
          DIMM A2 8GB DDR4 1Rx8 PC4-19200
          SMBIOS Profile 2400MT/s
          DIMM B1 Empty slot
          DIMM B2 8GB DDR4 1Rx8 PC4-19200
          Result summary
          Test Start Time 2024-10-23 04:18:25
          Elapsed Time 2:40:48
          Memory Range Tested 0x0 - 46E000000 (18144MB)
          CPU Temperature Min/Max/Ave 44C/64C/54C
          Lowest memory speed 2400 MT/s (17-17-17-39)
          Highest memory speed 2400 MT/s (17-17-17-39)
          # Tests Completed 48/48 (100%)
          # Tests Passed 16/48 (33%)
          Lowest Error Address 0x26138864C (9747MB)
          Highest Error Address 0x26338FFA0 (9779MB)
          Bits in Error Mask 00000000000000A0
          Bits in Error 2
          Max Contiguous Errors 1
          CPUs that detected memory errors { 0, 1, 7 }
          Bits in Error
          . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . x . x . . . . .
          63 0
          Test # Tests Passed Errors
          Test 3 [Moving inversions, ones & zeroes] 0/4 (0%) 33
          Test 4 [Moving inversions, 8-bit pattern] 0/4 (0%) 94
          Test 5 [Moving inversions, random pattern] 0/4 (0%) 113
          Test 6 [Block move, 64-byte blocks] 0/4 (0%) 760
          Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 485
          Test 8 [Random number sequence] 0/4 (0%) 119
          Test 9 [Modulo 20, ones & zeros] 0/4 (0%) 104
          Test 13 [Hammer test] 0/4 (0%) 16
          Last 10 Errors
          2024-10-23 06:59:08 - [Data Error] Test: 13, CPU: 0, Address: 26138E794, Expected: 291CF4D4, Actual: 291CF454
          2024-10-23 06:59:08 - [Data Error] Test: 13, CPU: 0, Address: 26138DB94, Expected: 520229D4, Actual: 52022954
          2024-10-23 06:58:38 - [Data Error] Test: 13, CPU: 0, Address: 26138F2C4, Expected: 5F58C246, Actual: 5F58C2C6
          2024-10-23 06:58:08 - [Data Error] Test: 13, CPU: 0, Address: 26138F59C, Expected: 60B25FAA, Actual: 60B25F2A
          2024-10-23 06:58:08 - [Data Error] Test: 13, CPU: 0, Address: 26138F594, Expected: 755DB3B0, Actual: 755DB330
          2024-10-23 06:57:39 - [Data Error] Test: 13, CPU: 0, Address: 26138E4F4, Expected: 2B86076E, Actual: 2B8607EE
          2024-10-23 06:57:10 - [Data Error] Test: 13, CPU: 0, Address: 26138DB94, Expected: 50D80DCC, Actual: 50D80D4C
          2024-10-23 06:40:12 - [Data Error] Test: 9, CPU: 7, Address: 26138F29C, Expected: CAF74AE2, Actual: CAF74A62
          2024-10-23 06:40:12 - [Data Error] Test: 9, CPU: 7, Address: 26138FDC4, Expected: CAF74AE2, Actual: CAF74A62
          2024-10-23 06:40:12 - [Data Error] Test: 9, CPU: 7, Address: 26138E794, Expected: CAF74AE2, Actual: CAF74A62
          Certification
          This document certifies that the Tests described above have been carried out by a suitably qualified technician on the System described above.
            Glad to hear it was fixed.
