Announcement
No announcement yet.
Automation, license keys, Read Only media
  • Filter
  • Automation, license keys, Read Only media
    I really like PT, and especially the automation switches. I would like to build myself a test stick or test CD (perhaps using autorun), so I can run PT on machines without installing it on them, or clicking anything during the test:
    Is there a way to turn off CD test and graphics test? I don't want to have to insert a CD rom AND a flash stick, one or the other would be nice.
    If I just use a flash stick. I am prompted to insert a CDROM for the CD speed test.
    If I just use a CDROM, I get a problem creating 3D textures on a read only media, asking me to click OK...
    The CSV, and html command line format options are great (details in help->contents->"Other Info"), but is there a way to get the detailed processor info saved in the binary format (cache size, cpu version, etc) into the csv file? or another text file? I have thought of using the .ini file feature with a small interval, generating a binary file which has the info on one fast warmup run, then generating a csv in a longer second run.
    I saw a post about putting the license key in a text file on the media, if you could point me to that info, or the "White Paper" that another poster referred to that would be great too.
    Thanks,
    John.
  • #2
    We are about to release a new point release of PerformanceTest that I believe covers everything you ask about. Among other features, PerformanceTest V6.1 includes the following:
    - Test scripting. You can specify whichever tests you want (and hence exclude the CD and graphics test);
    - You can now suppress the main test warning dialogs using a new option in Preferences;
    - The build of DirectX9.0c that PerformanceTest uses has been updated to October 2006. This no longer requires write access to the drive (ideal for CD's and Windows Vista);
    - The testing you describe can be done with a script. Note that V6.1 adds a new formatted text report type that includes the System information (such as CPU cache). eg.
    # Suppress the main test warnings during the script
    SUPPRESSWARNINGS ON
    # Set the preferences test duration
    SETDURATION 3
    # Run all tests except the 3D and CD tests
    RUN CPU_ALL
    RUN G2D_ALL
    RUN ME_ALL
    RUN DI_ALL
    # Save a Formatted text report
    EXPORTTEXTF "MyResults.txt"
    SETDURATION 30
    RUN CPU_ALL
    RUN G2D_ALL
    RUN ME_ALL
    RUN DI_ALL
    # Save a Formatted TEXT report (append results)
    # OK, start showing the warnings again
    SUPPRESSWARNINGS OFF
    Scripts can be run automatically using command line parameter /s <filename> (or from the Test -> Execute script menu option).
    Putting your key in a key.dat file is described at:
    http://www.passmark.com/support/pt6_faq.htm
    (section: Q. How can I set-up PerformanceTest to run from a CD or USB memory stick under Windows?)
    You can download a Beta of V6.1 from:
    http://www.passmark.com/ftp/petst611000_2.exe
    This is only a Beta and has known issues. We hope to release a public version of V6.1 in the next week.
    If you have any problems with this version, please send us email at:
    help [at] passmark [dot] com
    Ian
