CD-Maker and Performance Test
  • jaf
    • Aug 2006
    • 8
    I notice a wide variation in CD related performance tests, depending on the CD I happen to have in the drive at the time (I run Perf. Test 6 x64). I was going to ask about a feature to add the ability to burn a test CD from Performance Test, but noticed your free CD-Maker download.
    Would this be a good use of CD-Maker -- to use as a Performance Test baseline CD?
    Windows XP x64 Pro, AMD FX-8350, Kuhler h2o 920 cooling, 16 GB sys mem, EVGA GeForce GTX 760 OC Driver 320.49 (7/01/2013) Rosewill Bronze 1000w PS
    Yes.
    CD-Maker doesn't actually burn a CD for you. It just creates a standard set of files. You need to use the built in Window XP function or 3rd party CD burning software to actually get the files onto a CD.
    Unfortunately not everyone is using a CD like this. So there is a lot of variation due to the selection of various discs.
    • Windsurf48
      • Jun 2006
      • 57
      Wouldn't there be variations depending upon the media used to create the CDs even if the content were the same?
      Mike
        Probably some yes. But I think the drive and the disc contents are more important for read speed than the disc itself.
        • jaf
          • Aug 2006
          • 8
          Thanks. I use Performance Test to check my computer after major updates, just to see if anything has changed drastically, especially after a winXP x64 or graphics driver update.
          I'm not that interested in seeing how high a score I can get -- just a stable running system with scores that are reasonable with my hardware/software.
          Anyway, I created the CD and will use it as my baseline now.
          By the way, I noticed a slowdown in CPU Compression since going to 6.1. Should that be expected?
            The V6.1 result for compresssion should be roughly the same as in V6.0. Did you repeat the test a couple of times to see if it was a one off result?Did anything else in the system change between test runs?
            • jaf
              • Aug 2006
              • 8
              Sorry for the delay in getting back to you.
              I can't remember if I had the AMD "Cool 'n Quiet" utility running when I did the older baseline. All my CPU scores were better under this last 6.1 run except CPU Compression was 10% lower.
              I did add 2GB of memory for a total of 4GB (all the same brand and specs.)
              Anyway, no big deal -- just curious.
