I'm receiving this error on a few units here in the depot. So I looked up the information in the BIT documentation.
But I'm not using the torture test setting. I'm using the normal test setting. I restarted the PC and even used a HDD with a fresh OS, to see if it was indeed due to low resources. Both still failed.
Now I'm running another memory test (MemTest) to double check the memory. But so far everything is fine.
Any ideas?
*Edit: both MemTest passed just fine
Failed to start a memory test process
In the Multi-Process Torture Test, one of the test processes failed to start. This is normally due to insufficient system resources and is not specifically a RAM error. Check and possibly reduce the "Torture test settings" in Preferences->RAM
Any ideas?
1 296288 PASS 0 No errors
