Disk, C: Data Verify failure, Sound, No operations reported in timeout period
  • Sharon
    • Aug 2016
    • 32
    Platform: Intel Coffee Lake
    OS: Windows 10 RS4
    Burn in version: v8.1 Pro 1025
    Every cycle: 8-12hrs
    Error list as below:
    1st cycles: Disk, C: Data Verify failure, Sound, No operations reported in timeout period
    2nd cycles: system crash,abnormal shutdown, can't boot to OS again.
    3rd: Pass
    4th: Sound, No operations reported in timeout period
    Could you help check the log files?
    Thank you very much.
    Disk error is a error on the disk, a cyclic redundancy check. Most likely reason is that the disk is bad,
    One log showed potential temperature issues
    Temperature, Temperature threshold exceeded
    Temperature HDD 0 (ST1000LM035-1RK172): Current 100.0C / Threshold 90.0C
    So maybe the disk was too hot. 100C is pretty hot for a drive.
    'No operations reported in timeout period' for the sound test means the sound driver crashed or the whole system was super slow. If the system was super slow it might be due excessive load and / or due to memory leaks, which cause a lack of free RAM, which in turn cause disk swapping. Once you start disk swapping then the system can fairly quickly start to thrash under high load. Thrashing then leads to timeouts and crashes.
    • Sharon
      • Aug 2016
      • 32
      Thanks for your quick response.
      I will check the disk status and system performance.
