Sleeper V1.3 Build 1001
  • Anonymous
    • 286
    Hello
    I have come across this software which i beleive it will help with my automating of my PC as a Personal Video Recorder (PVR) due to the wakeup in number of seconds feature.
    What i need to understand is the Command Line syntax as it does not seem to work e.g.
    "F:\C DRIVE\Download\_PassMark Sleeper\Sleeper.exe" sleeper –S3 –D 60
    or is it
    "F:\C DRIVE\Download\_PassMark Sleeper\Sleeper.exe" –S3 –D 60
    These two lines are taken from shortcut settings. Also when i add the same syntax to my VB6 programme e.g.
    strPVR = "F:\C DRIVE\Download\_PassMark Sleeper\Sleeper.exe sleeper –S3 –D 60"
    it still does not work.
    Am i doing something wrong???
    Many thanks
    Mike
    The command line for V1.3 is,
    sleeper.exe -S1 -D 30
    Which means to enter sleep state 1 for 30 seconds.
    but depending on what directory you are in and in you are using a DOS window of some programming language you might need to add inverted comma and a full path and further changes.
    For example,
    "C:\Program files\Sleeper\sleeper.exe" -S1 -D 30
    And in C++ programming,
    "\"C:\\Program files\\Sleeper\\sleeper.exe\" -S1 -D 30"
    We don't do any VB6 programming so we can't help you much in that regards.
    Also in V2 of Sleeper (coming soon) there will be additional command line parameters.
    • scag
      • Feb 2005
      How many seconds is the maximum?
      Hello
      Many thanks for your previous reply
      I tried to send a email to support@passmark.com but it got returned back to me, unable to send???
      I am using your software to work with my Personal Video Software (PVR), the standby mode S3 by a number of seconds is exactly what I want. The difficulty I have is finding out what is the maximum number of seconds sleeper can except as the PC may need to be in standby mode for over 24 hours if I am away from home??
      Also are you planning to update sleeper? As the ability to run a programme once out of sleep mode would be ideal.
      Many thanks
      Mike Simmonds
        The E-Mail support@ E-Mail address has been dropped. It was getting 200+ spam E-mails a day. The new E-mail address is help@
        Entering a 24hour time period should be no problem.
        V2.0 of sleeper is already available and we are planning some additional minor updates at the moment.
        We have made a note of your feature request.
