Nvidea GTX1080 Low direct x complex 9 scores
  • Almayda
    • Jul 2016
    3D Graphics Mark
    #1 - NVIDIA GeForce GT 630 433.3
    #2 - ATI Radeon HD 5770 1642
    #3 - NVIDIA GeForce GTX 550 Ti 1998
    #4 - Intel(R) HD Graphics 4000 462.0
    #5 - AMD Radeon HD 6450 321.2
    #6 - NVIDIA GeForce GTX 980 10341
    My Baseline (2016- 5-2 - NVIDIA GeForce GTX 960 5201
    This Computer 6337
    Graphics 3D - DirectX 9 Simple
    #1 - NVIDIA GeForce GT 630 41.8
    #2 - ATI Radeon HD 5770 109.6
    #3 - NVIDIA GeForce GTX 550 Ti 141.1
    #4 - Intel(R) HD Graphics 4000 26.8
    #5 - AMD Radeon HD 6450 34.5
    #6 - NVIDIA GeForce GTX 980 799
    My Baseline (2016- 5-2 - NVIDIA GeForce GTX 960 418.2
    This Computer 1129
    Graphics 3D - DirectX 9 Complex
    #1 - NVIDIA GeForce GT 630 23.0
    #2 - ATI Radeon HD 5770 48.6
    #3 - NVIDIA GeForce GTX 550 Ti 61.7
    #4 - Intel(R) HD Graphics 4000 16.3
    #5 - AMD Radeon HD 6450 12.3
    #6 - NVIDIA GeForce GTX 980 174.8
    My Baseline (2016- 5-2 - NVIDIA GeForce GTX 960 87.9
    This Computer 52.9
    Graphics 3D - DirectX 10
    #2 - ATI Radeon HD 5770 19.7
    #3 - NVIDIA GeForce GTX 550 Ti 22.0
    #4 - Intel(R) HD Graphics 4000 4.04
    #5 - AMD Radeon HD 6450 2.34
    #6 - NVIDIA GeForce GTX 980 164.0
    My Baseline (2016- 5-2 - NVIDIA GeForce GTX 960 66.0
    This Computer 131.7
    Graphics 3D - DirectX 11
    #2 - ATI Radeon HD 5770 30.3
    #3 - NVIDIA GeForce GTX 550 Ti 34.5
    #4 - Intel(R) HD Graphics 4000 7.9
    #5 - AMD Radeon HD 6450 4.54
    #6 - NVIDIA GeForce GTX 980 222.1
    My Baseline (2016- 5-2 - NVIDIA GeForce GTX 960 108.3
    This Computer 310.7
    Sounds a bit like this post.
    To start with can you rule out these causes,
    1) Does your monitor have freesync/G-Sync? As these have been seen to cap frame rates.
    2) You are running Shadowplay, or similar screen recording software. This can happen without you knowing it, as some of it is now being auto-installed with drivers.
    Also,
    3) What are the rest of the hardware specs?
    4) What video card device driver version are you using?
    • Almayda
      • Jul 2016
      no my monitor doesnt have freesync of g_sync and am not running shadow play. am running the latest Driver for my card version 373.06 and the rest of the hardware specs:
      Operating System: Windows 10 Professional Edition build 10586 (64-bit)
      CPU Type: Intel Core i7-6700K @ 4.00GHz
      Number of CPUs: 1
      Cores per CPU: 4
      Hyperthreading: Enabled
      Motherboard: Z170-P D3
      Memory: 32GB Kingston DDR3 SDRAM
      Videocard: NVIDIA GeForce GTX 1080
      Hard Drive: ST1000DM003-1CH162 (1TB)
      Hard Drive: TS512GSSD370 (512GB)
      Hard Drive: TS512GSSD370S (512GB)
      Power Supply: Cougar SL 600w (can power shortage cause a prob like this with dx9) ?
      • Almayda
        • Jul 2016
        PassMark(R) PerformanceTest 8.0 (http://www.passmark.com)
        Results generated on: Thursday, October 20, 2016
        Benchmark Results
        Test Name: This Computer
        CPU - Integer Math: 19634.0
        CPU - Floating Point Math: 8169.3
        CPU - Prime Numbers: 25.9
        CPU - Extended Instructions (SSE): 52.9
        CPU - Compression: 15601.5
        CPU - Encryption: 2609.7
        CPU - Physics: 581.9
        CPU - Sorting: 9041.7
        CPU - Single Threaded: 2353.4
        Graphics 2D - Simple Vectors: 26.8
        Graphics 2D - Complex Vectors: 181.5
        Graphics 2D - Fonts and Text: 269.3
        Graphics 2D - Windows Interface: 155.4
        Graphics 2D - Image Filters: 464.0
        Graphics 2D - Image Rendering: 1119.2
        Graphics 2D - Direct 2D: 64.6
        Graphics 3D - DirectX 9 Simple: 1177.3
        Graphics 3D - DirectX 9 Complex: 52.7
        Graphics 3D - DirectX 10: 131.9
        Graphics 3D - DirectX 11: 313.8
        Graphics 3D - DirectCompute: 7306.7
        Memory - Database Operations: 113.1
        Memory - Read Cached: 32154.1
        Memory - Read Uncached: 16191.7
        Memory - Write: 10976.3
        Memory - Available RAM: 30553.3
        Memory - Latency: 26.0
        Memory - Threaded: 21254.0
        Disk - Sequential Read: 489.3
        Disk - Sequential Write: 243.9
        Disk - Random Seek + RW: 321.7
        CPU Mark: 10687.5
        2D Graphics Mark: 855.4
        Memory Mark: 2904.4
        Disk Mark: 3815.2
        3D Graphics Mark: 6344.0
        PassMark Rating: 4905.7
          The latest drivers include shadowplay. It gets installed without you knowing about it. So are you sure it isn't installed?
          • Almayda
            • Jul 2016
            Shadowplay is now called "Share" dunno why its there in the nvidea geforce general tab but its switched off here
            • Almayda
              • Jul 2016
              any help please?
                It might be worth checking the power settings in the Nvidia control panel > Manage 3D settings > Global settings > Power management mode. Try the different power options and see if it affects the result. Also make sure that the DSR - Factors option is turned off.
                • Roberto F Rossi
                  • Aug 2016
                  • 13
                  Directx 9 complex just scores normally for me if I put the nvidia device driver image settings to "balanced" or "quality" (without customizing).
                  Using the nVidia "performance" setting reduces my score down by 50%.
                  NVIDIA settings performance scores 60fps, balanced 130+fps (using gtx 1060 6gb zotac amp!).
                  When i had a 960 it'was clear too that the test didn't use more than 50% gpu usage, seeing via osd/rivatuner, so I had, to hit maximum to enter Passmark performance test via balanced quality, run the directx 9 test, change the quality to performance, and run directx 10,11,12,and the other test. I've hit 11300 3d score with my geforce 1060 amp! zotac 10% overclock. 0% overvoltage.
                    We don't currently have a GTX 1060 to test with and are looking at getting one however we ran some tests with a GTX 960 and GTX 970 and didn't see the same drastic changes as you are getting;
                    GTX 970 Win7
                    Power policy DX9 DX10 DX11 GPUCompute
                    Optimal Power 152 132 182 4566
                    Adaptive 152 132 182 4477
                    Prefer max 151 132 182 4585
                    GTX 960 Win10
                    Power policy DX9 DX10 DX11 DX12 GPUCompute
                    Optimal Power 135 72 87 22 3696
                    Adaptive 135 72 86 22 3652
                    Prefer max 135 72 86 22 3685
                    We also tried the "Adjust image settings" options, Performance, Balanced and Quality and saw a bigger difference (due to the number of settings that are changed) but this was still only ~15% for the DX9 test;
                    GTX 970 Win7
                    Image Settings DX9 DX10 DX11 GPUCompute
                    Performance 160 147 184 4504
                    Balanced 154 147 180 4371
                    Quality 136 145 173 4312
                    GTX 960 Win10
                    Image Settings DX9 DX10 DX11 DX12 GPUCompute
                    Performance 145 77 89 22 3717
                    Balanced 146 77 87 22 3645
                    Quality 132 77 84 22 3614
                    • Roberto F Rossi
                      • Aug 2016
                      • 13
                      Thank you Tim for replying me. It must be my specific hardware that causes it then! I love performance test!
                        We just tested a GTX 1060 here (Win10) and saw some similar results to what you are seeing, when the Nvidia device driver image settings are set to "Performance" the DX9 results will decrease. Which is the opposite of what should happen.
                        GTX 1060
                        Image Settings DX9
                        (Frames per sec)
                        Performance 192
                        Balanced 226
                        Quality 223
                        We also ran the test using the "Advanced 3D" options to try some different resolutions and AA settings and still saw the same decrease in the result when the "Performance" settings was used.
                        I think the only explanation is that this is a nVidia device driver bug / quirk for the GTX 1060 card.
                        • Roberto F Rossi
                          • Aug 2016
                          • 13
                          When I had a gtx 960 amp! from zotac with windows 10, I had the same issue.
                          Its not like the graphics card loses power.... the fact is that it uses less than it has, saving power (no matter what the options you use) and I dont know why.
                          GPU USAGE GTX 960/1060 ZOTAC AMP! WINDOWS 10 (I had both cards from the same manufacturer) performance test 9, amd processor, pci-e 2.0 x16 slot.
                          dx 9 complex - performance 60% GPU usage - balanced 85% gpu usage, quality ~~near balanced, but 1-2 fps lower.
                          dx 10 - 91-97% gpu usage (using 100% gpu a gtx 1060 wins a 980)
                          dx 11 - variable from 85%+, finishing with 99% gpu usage
                          dx 12 - my rivatuner (msi afterburner) do not work with dx 12 for me to know the real gpu usage
                          dx compute - some parts work with rivatuner statistics server (on screen display) and I can see a high gpu usage
                            The DX9 test runs at the lowest resolution of the four 3D tests. So it isn't surprising that the GPU load is a bit lower (and the dependency on CPU performance is higher).
