./pt_linux_x64 doesn't work on my x64 machine
  • starz
    • Oct 2021
    $ ./pt_linux_x64 # there is no output
    $ strace ./pt_linux_x64 # prints
    execve("./pt_linux_x64", ["./pt_linux_x64"], [/* 33 vars */]) = -1 ENOEXEC (Exec format error)
    write(2, "strace: exec: Exec format error\n", 32strace: exec: Exec format error
    ) = 32
    exit_group(1) = ?
    +++ exited with 1 +++
    and here is the information about my machine:
    Linux version 4.18.0 (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.11)) #1 SMP Fri Sep 24 02:26:50 CST 2021
  • starz
    • Oct 2021
    sorry, it's because my file upload is incomplete
      OK, glad you sorted it out.
      • Rainer
        • Mar 2013
        Unfortunately I have the same problem as the OP, but not a corrupted download. I'm running Ubuntu 20.04.3 LTS, and can't get past
        ./pt_linux_x64: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
        I already set LD_LIBRARY_PATH to /snap/core18/2128/lib/x86_64-linux-gnu where I located libncurses.so.5 on my computer. However, I still get the same error message. What to do?
        Thanks, Rainer
          • 337
          See the FAQ question: 'I am getting "error while loading shared libraries: libxxx.so.x: cannot open shared object file:
          No such file or directory?" error when I launch BurnInTest Linux from the command line, why?'
          On this page: https://www.passmark.com/support/bitlinux_faq.php
          Should apply for PerformanceTest as well.
          - libncurses.so.5
          Some newer versions of Linux are now shipping with a newer version of ncurses (6) than BurnInTest was built with (eg Fedora 25). If you see this error messages you should be able to install "ncurses-compat-libs" which will install a version 5 compatible ncurses library. You can do this with "yum install ncurses-compat-libs".
          - libtinfo.so.5
          Some distributions split the ncurses library into several files and others use a single file. If you are missing the libtinfo library you can create a link from the ncurses library to it. First check where the libncurses.so.5 library is being linked from by running the ldd command, eg "ldd bit_cmd_line_x32" it should be /lib or /usr/lib.
          Then create links to the ncurses library like this (changing /lib to /usr/lib if necessary);
          ln -s /lib/libncurses.so.5 /lib/libtinfo.so.5
          ln -s /lib/libtinfo.so.5 /lib/libtinfo.so
          When using a 64 bit version of linux and running bit_cmd_line_x64 you would need to link the 64 bit libraries;
          ln -s /lib64/libncurses.so.5 /lib64/libtinfo.so.5
          ln -s /lib64/libtinfo.so.5 /lib64/libtinfo.so
          • oskars
            • Feb 2022
            The same problem with outdated ncurses lib on Ubuntu 21.10 (./pt_linux_x64: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory). The same will be with coming LTS release Ubuntu 22.04.
            Not possible to install "ncurses-compat-libs".
            Please compile with contemporary libraries.
              You can still install libncurses5 in Ubuntu 21.10;
              Code:
              sudo add-apt-repository universe
              sudo apt-get install libncurses5
                Linux is a dumpster fire for binary compatibility.
                If we compiled with the newest library, then the software wouldn't work on even slightly old machines.
                • kapqa
                  • Feb 2021
                  • 18
                  i had to install 2 packages for ubuntu 22.04 since libncurses5 would only offer i386 for some reason.
                  went here and downloaded
                  1. https://www.ubuntuupdates.org/packag...ates/libtinfo5
                  and
                  2. https://www.ubuntuupdates.org/packag...es/libncurses5
                  the amd64 versions respectively
                  and installed via "sudo dpkg -i" number 1 and 2.
                  maybe for 24.04 newer versions are required.
                  EDIT> sorry, i am on 24.04 , maybe this solution is needed only for 24.04< or works also for 22.04?
                  in any case , with 24.04 now able to run ./pt_linux. Passmark Performance Linux Test.
                  • turcotte
                    • Aug 2024
                    What steps can I take to resolve the "error loading shared library: libxxx.so.x: cannot open shared object file: No such file or directory" error when launching BurnInTest Linux from the command line?
                      Note that post was about PerformanceTest (which is different software from BurnIntest)
                      But see the Linux FAQ page for details about Linux shared libraries for BurnInTest.
                      (the problem is similar for all Linux software however)
                      • Alelele98
                        • Apr 2025
                        To install libncurses5 on Ubuntu 24.04 and newer:
                        Code:
                        echo "deb http://security.ubuntu.com/ubuntu focal-security main universe" > /etc/apt/sources.list.d/ubuntu-focal-sources.list
                        apt update
                        apt install libncurses5
                        • raywood
                          • Apr 2025
                          On U 24.04, that echo command (even when preceded by sudo) results in "Permission denied."
                          • 3steve3
                            • Apr 2025
                            Is it possible for you to statically link the ncurses library?
