low score on CPU Mark
  • giboune
    • Feb 2021
    I follow others topics and I know that I need to reinstall Windows to get a better score (thank you Asus software). I'm very disappointed to buy a Asus mobo.
    37893pts with a 5950x. With bad Floating point math score.
    I just would like to know if this setting it's important for gaming ?
    It's the first benchmark where I get a bad score... and I'm disturbe... sorry to be like a child (40 years old child)...
    Thank you.
    I guess you are referring to these posts
    https://forums.passmark.com/performa...ath-tests-help
    https://forums.passmark.com/performa...ger-math-score
    https://forums.passmark.com/performa...nd-freqs/page2
    I don't think anyone has done the testing to prove if it has much effect on gaming or not. Likely different games would show different behaviour in any case. Certainly floating point maths is used in a lot of applications.
    • giboune
      • Feb 2021
      Just to tell you, I finally reinstalled Windows 10 and I get 47082pts (37893 before) on CPU Mark.
      I'm happy... lol
      • Svemir
        • Mar 2021
        sorry to interrupt,
        one question on my intel core i3-10100F, I get half ( 4606 ) of the standard score ( 8085 ) in what cold be the problem ( reinstaling Windows perhaps )?.
          Svemir,
          What are the individual benchmark results. What hardware are you using (maybe an ASUS motherboard?)
          A couple of weeks ago ASUS confirmed a bug in their AI Suite software. It was making machines slower instead of faster.
          • Svemir
            • Mar 2021
            Passmark 1101
            cpu mark 5140
            2D mark 148
            3D mark 249
            memory mark 2807
            disk mark 4029
            my graphic card is very bad
            • Svemir
              • Mar 2021
              Originally posted by Svemir
              Passmark 1101
              cpu mark 5140
              2D mark 148
              3D mark 249
              memory mark 2807
              disk mark 4029
              no i don’t have asus motherboard it is asrock and it works fine on geekbench 5 everything it’s as it should be
                Svemir,
                Except for the CPU model, we don't know what hardware you are using. So maybe the results are normal for your hardware.
                For the CPU, the result does seem a bit low. It would be good to see the individual CPU benchmark results.
                See also this post for coverage of all the common performance issues.
                • Svemir
                  • Mar 2021
                  My hardware is
                  antec psu 500w
                  intel core i3-10100F Cpu
                  two SSD disks 550/530 R/W
                  and bad graphic card but works AMD Radeon HD 6570
                  two Patriot 4GB DDR4 2400MHz
                  Asrock - H410M-HVS motherboard
                  nothing special
                    What are the temps for the CPU during operation? Possibly check that cooling is adequate (e.g. CPU paste not properly applied, or heatsink not attached properly).
                    If you uploaded a baseline to our database, provide the baseline number and we can take a quick look at the results.
                    Refer to the post mentioned previously for coverage of all the common performance issues
                    • Svemir
                      • Mar 2021
                      temps are about 30 degrees everything is ok no i did not uploaded baseline to database
