Sorry for the delay in responding.
Can you please confirm that you are running from BartPE as these files are only skipped in the CD test if you are running BartPE (and yes it does not matter where you run BurnInTest from in this case)?
I did test this so I wonder if the BartPE detection is not quite right for your system. Can you confirm that when you start any tests you see the following message:
Please note that only a subset of tests are supported under BartPE.
Please refer to the online documentation.
If not, then we have a problem with BurnInTest detecting BartPE and we'll create a debug version of BurnInTest to investigate.
Thanks.
Ian (PassMark)
Thanks.
Ian (PassMark)
