This is a sticky topic.
  • leandrolnh
    • Jun 2017
    Hello, I'm experiencing the same issue as the ASUS B350 board related in the reference post.
    My configuration:
    ASUS Prime X370-PRO
    BIOS 0805
    AMD Ryzen 7 1700X
    Issue:
    UEFI mode does not start, reboots after "Checking memory controller". Log attached.
      This is an issue that ASUS has acknowledged and appears to be working on a fix. We have blacklisted this board in the meantime.
      Try the following build:
      http://www.passmark.com/ftp/memtest86-usb-7.3.1020.zip
      • leandrolnh
        • Jun 2017
        Thank you! It's now working.
        • valdir.silve
          • Aug 2017
          Asrock P67 Extreme 6 is also affected.
          UEFI L2.19 (latest available UEFI / beta)
          - Parallel runs fine (4 passes without problems)
          - robin ka
          - sequential freez after test 1 (CPU core switch = freez)
          Will you contact asrock for a fix?
          • szoo0268
            • Sep 2017
            MB: supermicro X9SRA/X9SRA-3
            BIOS revision : R 3.2
            CPU: E5-1620 V1
            PC shuts down and reboot after "Testing multiprocessor support" show up , need to add this into the blacklist, thx.
              CPU: E5-1620 V1
              The MB has been added to the list.
              By chance do you still have the MemTest86.log file that we can take a look at?
              • szoo0268
                • Sep 2017
                Here you are.
                The original file is too big, so i deleted something from other PC's test .
                • mh001
                  • Oct 2017
                  One more Supermicro:
                  MB: X9DRW-7TPF (rev1.02 if important)
                  BIOS: revision 3.2
                  CPU: 2 x E5-2620 v2
                  • rem356
                    • Feb 2018
                    Hi, here's my info:
                    Motherboard model number: ASUS M5A99X EVO R2.0
                    BIOS version: 2501 (Edit: this is the last BIOS update for this motherboard)
                    CPU: AMD FX-6100
                    Issue: PC shuts down and reboot after "Testing multiprocessor support"
                    The issue is in V7.5 Free Edition. The V4.3.7 in Free Edition works fine.
                      rem356, can you check for BIOS updates from ASUS.
                      • rem356
                        • Feb 2018
                        It's the last BIOS update for this motherboard.
                          Looks like the ASUS M5A99X EVO BIOS hasn't been updated for 5 years. Which is a while for a UEFI BIOS. Likely it is buggy.
                          • rem356
                            • Feb 2018
                            Yeah, it's old, luckily version 4 worked. Thanks for answering.
                            • Artiphax
                              • Mar 2018
                              Having issues running the test on a Dell Precision T5600 Dual Xeon system. The software takes a good amount of time to load, starts, and then displays about 1/2" of blue and green bands at the top of the screen before crashing out to a black screen.
                              Here are the specs:
                              BIOS: A14
                              Processors: Dual E5-2643 processors
                              Memory: Current config is 96GB of ECC DDR3 RDIMM (I dropped some memory hoping that taking a bit out would allow the test to run, it didn't though)
                              Boot Sequence is set to UEFI
                              I've also tried it with two video cards, same exact result. First setup was an Nvidia SLI Quadro 500 setup, second video setup was a single AMD HD4650.
                              I'm hoping that them memory test helps shed some light on some buggy issues. The Dell diagnostic says everything is fine, but the system acts weird under load.
                              • coal12
                                • Mar 2018
                                I am having issues with a Dell T5600 system.
                                My Configuration:
                                Dual Xeon E5 - 2620 processors
                                BIOS version A15
                                40 gbs of DDR3 ECC RDIMMS
                                Tests run fine if I boot up the Legacy Bios Memtest v4 cycling through the CPU's. However, I run into issues when I boot the UEFI v7.5. It loads just fine for me and I can get the menu. CPU multiprocessor selections are disabled entirely stating possible problems with an old UEFI system. When I try to run in single processor mode, it gets to 6% done on the first test no matter which test I start with and then crashes, restarting the computer.
